December 3, 2014, 13:40 |
Convergence issue
Dhayananth
Rep Power: 11 |
During my flow simulations in fluent, the residuals never meet the convergence condition but also no longer decreasing. I also run the case by changing under-relaxation factors, but its showing same behavior. I am using SIMPLE algorithm and second order upwind scheme for discretization. How can I judge whether it is converged or not? with regards, Dhayananth |
December 5, 2014, 09:58 |
Rep Power: 12 |
convergence is often a big issue. You should not only look at the residuals. I would recommend you to plot some solution variables, you are interested in. They can tell you whether or not your solution is converged. To lower your residuals I would recommend you: - use the first order upwind schemes, they are easier to converge - try increasing/decreasing the URF. I had some trouble with continuity and increasing the pressure URF helped - If you are using coupled, reducing the courant number might help regards student |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Convergence issue with continuity equation | Jake | FLUENT | 8 | June 6, 2018 03:41 |
convergence issue with turbulence | mar | Siemens | 5 | February 2, 2015 02:42 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Convergence issue | Jake | FLUENT | 3 | June 30, 2005 04:12 |
