December 8, 2014, 12:24 |
Amount of heat flux
ayden
Rep Power: 12 |
Hi
I have cross flow finned tube heat exchanger with perforated annular fins as shown below. constant temp. B.C applied to inner diameter of the pipe, I tried to calculate HTC by [q=h*A(Ts ـــ Tref)]. Heat flux (q) value in perforated fin must be larger than solid fin to produce smaller surface temperature than solid fin as we can see in pic. On the contrary happen in my model just in case of (q). I use this method to find (q), Is it right |
December 9, 2014, 03:33 |
Rep Power: 26 |
See my first reaction of http://www.cfd-online.com/Forums/flu...-temp-b-c.html.
Conjugate Heat Transfer: Wall Heat Flux at Coupled Walls? | MaxHeat | FLUENT | 4 | September 14, 2017 10:44 |
Calculating heat flux | hugo17 | OpenFOAM Post-Processing | 4 | May 27, 2015 12:47 |
Monitor Heat Flux in CFD-Pre | cltormar | CFX | 5 | November 20, 2014 11:45 |
Wall Heat Flux not a listed variable | mike | CFX | 8 | February 5, 2009 13:32 |
Wall heat flux | cujo | CFX | 3 | November 6, 2002 03:43 |
