August 17, 2000, 18:35 |
reference values - 2D airfoil model
Hi. I'm working at drag and lift about an airfoil, but I can't found some information related to how to setup the area and depth in the 2D model. Clearly I can to see the area in a 3D model but must I to setup it by the nearest value? Thanks a lot if anyone can help me.
August 20, 2000, 18:24 |
Re: reference values - 2D airfoil model
If the case is 2D, then the span of the airfoil is infinite. All values in Fluent are then calculated for a span of 1 unit. Therefore, if you have an airfoil with a chord length of 1 meter, Fluent will calculate forces and moments for a span of 1 meter and an area of 1 sq. meter.
August 20, 2000, 18:25 |
Note, the 2D model does not include wingtip vortices for drag calculations
November 24, 2011, 01:12 |
Shibin Mohamed
Rep Power: 14 |
I have my NACA 23015 airfoil(flow speed 36m/s) which has a chord length of 100mm, max thickness 15.05mm,...
after scaling the grid to metres...what should be the reference values for area, length and depth... i am unable to obtain correct values for Cl and Cd...please help its very urgent.... |
February 5, 2014, 10:37 |
Depth and length
Tushar K Herle
Rep Power: 12 |
What r the area, depth and length in those reference values??
February 6, 2014, 09:15 |
Deutschland
Rep Power: 12 |
hey guys,
I had the same problem 2 month ago. I fixed it in that way, that i calculate the drag and lift coefficient by myself. cd = F_Drag / (p_dyn * A) F_Drag can you calculate under Forces. pdyn is density / 2 * u. For the area, you have to define any area you want. For example chord length * width or frontal area. I hope this fixed your problem. |
April 1, 2015, 18:33 |
#7 | |
Ronald Thompson
Rep Power: 11 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
It would be wonderful if a tool for FoamToTecplot is available | luckyluke | OpenFOAM Post-Processing | 165 | November 27, 2012 06:54 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
Windows Installation BugsComments on Petrbs patch | brooksmoses | OpenFOAM Installation | 48 | April 16, 2006 00:20 |
