scaling 2d axisymmetric mesh
Old   February 7, 2015, 23:39
Default scaling 2d axisymmetric mesh
Lucky
I'm trying to do circular pipe with periodic boundary conditions in 2D.
I generated a 2D mesh for axisymmetric simulations in non-dimensional coordinates which get interpreted as meters when imported into Fluent. I need to scale the mesh from meters to inches. Axis is properly at y=0 (+/- ascii error) and domain extends 0<y<1.
I get floating point errors if I scale the mesh and try to run a simulation. The simulation works fine if I don't scale the mesh. The floating point errors occur only when using streamwise periodic boundary condition & when scaling the mesh. I can scale the mesh using normal pressure, velocity inlets without floating point errors. I have tried defining the periodic b.c. before and after scaling, the same floating point error occurs.
I can just generate a new mesh in dimensional coordinates but does anyone know a general solution on how to scale the mesh within Fluent?
edit* even with mesh generated in inches, same issues. So it seems there are some issues with the generated mesh and/or Fluent detection of axis. Any fixes?
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
Mesh check fail after scaling Aoki FLUENT 0 February 11, 2014 15:03
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
