boundary condition at outlet for microchannel flow
Old   February 5, 2015, 11:49
Post boundary condition at outlet for microchannel flow
joseph
josephmp is on a distinguished road
Hi all, i have just started studying ansys fluent. what i have to find is the pressure drop in a microchannel with a specified velocity inlet and length of pipe. Nothing is known about outlet conditions. the outlet pressure need not be atmospheric. In such a case what should be my outlet boundary condition?
josephmp is offline   Reply With Quote
Old   February 5, 2015, 12:40
edoan's Avatar
Ethan Doan
edoan is on a distinguished road
you can use pressure outlet condition just set a pressure at the outlet and the inlet with adapt to give you the correct pressure drop.
edoan is offline   Reply With Quote
Old   February 6, 2015, 15:27
joseph
thank you for answering....but i didnt get the method clearly. what do you mean by adapt? can you plz be a little more elaborate?
Old   February 6, 2015, 15:39
edoan's Avatar
Ethan Doan
Lets say the pressure drop in your system should be x Pa. if you set the outlet to y Pa then the inlet pressure will be equal to x+y Pa. do you get my point?
Old   February 9, 2015, 01:09
joseph
thank you very much....since i m interested only in the pressure drop your advice helped me...but for information may i ask is there any method to input the inlet pressure and find the outlet pressure as a result of it?
Old   February 9, 2015, 08:10
edoan's Avatar
Ethan Doan
sorry joseph i haven't done anything like that i am not sure if there is a good way. I am thinking you can switch the position of your pressure outlet and velocity inlet where you specify the velocity at the inlet as negitive so it is essentially an outlet and your pressure "outlet" is your inlet.
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Boundary Condition for reacting species flow at outlet Astrodan OpenFOAM Running, Solving & CFD 0 September 25, 2014 10:59
pressure outlet boundary condition hamid_reza Fluent Multiphase 1 September 9, 2014 13:43
outlet boudary condition for a flow in the pipe Atit CFX 2 November 9, 2004 17:43
Impinging Jet. Outlet Boundary Condition Vincent Main CFD Forum 0 December 16, 2003 10:49
