"incident radiation" vs. "surface incident radiation" |
February 4, 2015, 07:59 |
Rep Power: 11 |
Hi all,
can anyone explain me the difference between the quantity "incident radiation" (unit W/m2, under Radiation...) and "surface incident radiation" (also W/m2, under Wall fluxes...)? Thanks in advance philus |
February 26, 2016, 00:49 |
Saurav Chakraborty
Rep Power: 12 |
Hi philus
I had the same query.. Did you find the answer ? Thanks Saurav |
March 9, 2016, 06:01 |
Rep Power: 11 |
I had found an empirical answer to that and was something like:
the wall fluxes->incident radiation is the radiating energy flux incident to the surface, while the radiation->incident radiation is the sum of all radiation (incident, transmitted and reflected) on both sides of the selected CELL. But it is still foggy for me I'm sorry.. |
March 9, 2016, 06:08 |
Saurav Chakraborty
Rep Power: 12 |
Yes i figured out that the one under wall fluxes is the one i require.
March 9, 2016, 10:27 |
Lucky
Rep Power: 66 |
Incident radiation can be computed/visualized at any arbitrary location (a point placed anywhere in the domain).
Surface incident radiation under wall fluxes is limited strictly to walls. It's similar to a local heat flux vs the wall heat flux. |
December 6, 2019, 15:26 |
Junjun Guo
Rep Power: 6 |
I find the incident radiation on the wall is different from sureface incident radiation.
Fluent incident radiation problem | Michael Schwarz | Main CFD Forum | 0 | October 21, 1999 05:56 |
