February 5, 2015, 08:30 |
nozzle in fluent
FC
Rep Power: 11 |
I'm simulating a convegent divergent nozzle in fluent with air. I've noticed that the AreaAvarage pressure in inlet changes when I change the dimensions of the nozzle, even if I set as BC ambient pressure inlet; why does that happen? Otherwise I'm searching for the minor pressure drops from inlet to outlet, and I don't undestand why pressure drops seems that have more than one minimum value if I modify the length of the nozzle without changing the angles, but in theory pressure drops should be linear. Does anyone know what I'm probably missing? thank you very much. |
February 8, 2015, 05:18 |
#2 | |
sudhir
Rep Power: 17 |
Area Average concept is based on surface area...please check fluent documentation. |
February 8, 2015, 05:34 |
FC
Rep Power: 11 |
February 8, 2015, 05:41 |
#4 | |
sudhir
Rep Power: 17 |
The area-weighted average of a quantity is computed by dividing the summation of the product of the selected field variable and facet area by the total area of the surface.. check this link http://aerojet.engr.ucdavis.edu/flue...g/node1199.htm sudhir |
February 8, 2015, 06:03 |
#5 | |
FC
Rep Power: 11 |
Thank you for your help. |
February 8, 2015, 06:15 |
sudhir
Rep Power: 17 |
Node or mass weighted average would be a better choice in my opinion. Hope it helps..
February 8, 2015, 06:22 |
FC
Rep Power: 11 |
February 14, 2015, 00:28 |
sudhir
Rep Power: 17 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
Solid Rocket Nozzle - Fluent 5 Tutorial Guide | Ijaz | FLUENT | 4 | April 2, 2015 20:46 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
analyze a cd nozzle with fluent which designed by MOC | mehrzad | Main CFD Forum | 0 | July 6, 2011 04:33 |
Pressdrop across in nozzle: Fluent | Paul | Main CFD Forum | 8 | January 15, 2006 02:24 |
