Error The mesh file exporter does not support overlapping geometry in Contact Regions
Old   October 22, 2014, 11:26
Default Error The mesh file exporter does not support overlapping geometry in Contact Regions
sachinip is on a distinguished road
hello,
I am trying to mesh a filter holder. I have three parts, the part for the in flow, the filter (which i created it as a surface so as to later define it as porous jump) and the part for the outflow(the meshing tool recognizes the connections in between these parts).
However when I am trying to mesh it I receive the following error from fluent
Error:The mesh file exporter does not support overlapping geometry in Contact Regions. Please resolve the issue and try again.
I tried to use the match control but it did not work. I have not set the named section in this step since the solver cannot read my meshing.Can it be the problem?
Also, it cannot recognize the filter surface as a surface with 2 faces during the geometrical set up.
Since I am new in cfd I cannot completely inspect what is going wrong
Any recommendations?
Thank you very much
sachinip is offline   Reply With Quote
Old   March 11, 2015, 13:47
Bojan
Boky is on a distinguished road
Hello
I have similar problem, did you manage to solve this
Boky is offline   Reply With Quote
Old   March 11, 2015, 14:16
If you refered to the use of a surface as porus jump, ehat i did is to delete the problematic surface. Thus i have two parts, the upstream and downstream part. Then i create a new part that i assigned the two separate parts as one. So i can define the interferance of those parts as porus jump.
Hope it can help you
Old   March 11, 2015, 15:27
Bojan
Yessss, thank you kind sir
And really fast response
error, fluent
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 104 February 16, 2021 08:46
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 10:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 10:57
