velocity field incorrect between mesh partitions
Old   March 16, 2015, 05:54
Default velocity field incorrect between mesh partitions
Andrey Yakovchuk
einandr is on a distinguished road
Hi everyone!
I have strange behavior on mesh partition boundary. I use Fluent 16.0. The problem involves multiphase and wave BC. After initialization velocity fields for some reason incorrect on mesh partition boundary. I try inilialize in seril and save data file, but after opening it in parallel the partition boundary again like this.
It is really partition issue, when I use more processors I have more separations, when I run in serial - no problem. The rupture line corresponds to partitions.
Maybe this is 16.0 release bug or I do something wrong? I will try on different Fluent version, but so far I am really stick on that point.
einandr is offline   Reply With Quote
Old   August 20, 2015, 07:38
hayder
hayder is on a distinguished road
Hi einandr
Did you find the way to solve this problem, I got the same when I using dynamic mesh in parallel fluent
hayder is offline   Reply With Quote
Question on moving mesh, mesh velocity is really small! ripperjack Main CFD Forum 2 April 28, 2014 13:37
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 18, 2009 23:24
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
