March 19, 2015, 12:08 |
Tangential rms velocity
SHEIKH NASIRUDDIN
Rep Power: 12 |
Hello everybody,
I want to calculate y- rms velocity component in Fluent. The domain is rotating pipe and fluid is flowing thru it. RMS y-velocity can be calculated directly from unsteady statistics in fluent. But in my case that is coming erroneous. I want to calculate it using custom field function or user defined function using the following formula : RMS-y-velocity=sqrt(mean((y-velocity)-(mean-y-velocity))^2); and I want that while calculating using this formula it should take y-velocity and mean-y-velocity from fluent. Is there anyway to calculate it like this? |
ActuatorDiskExplicitForce in OF2.1. Help | be_inspired | OpenFOAM Programming & Development | 10 | September 14, 2018 11:12 |
FFT of RMS velocity component | M_Tidswell | FLUENT | 2 | March 7, 2014 09:52 |
Draw the tangential, axial and radial velocity for flow section | Al-Hashimi | FLUENT | 3 | August 12, 2013 01:16 |
Wall BC of the tangential velocity for inviscid simulation | nickna | Main CFD Forum | 1 | March 12, 2013 11:33 |
Radial and tangential velocity | Antonio Mileo | FLUENT | 2 | February 16, 2001 01:41 |
