Fluent Boundary Conditions
Like Tree1Likes
  • 1 Post By LuckyTran
Old   April 2, 2015, 20:58
Default Fluent Boundary Conditions
anonymous
anonymousbach is on a distinguished road
Hi All,
I'm trying determine the surface nusselt numbers on a single 2D cylinder in a rectangular domain. The domain has constant pressure and temperature on all 4 sides. The gauge pressure is assumed to be 0.
I'm having trouble coming up with the proper boundary conditions. Initially I thought I could treat two walls as inlets and 2 walls as outlets but the nusselt numbers change significantly depending on which walls are inlets or outlets. Is there a way to model an "ambient" atmosphere in Fluent, with just constant pressure all around?
Thanks for any help, it would be much appreciated!
anonymousbach is offline   Reply With Quote
Old   April 3, 2015, 01:05
Lucky
Usually a constant pressure inlets and outlets are used.
Naturally convection problems are tricky to model because of contamination of the boundary condition onto the modeled domain. The rectangular box domain needs to be large enough that the constant pressure inlets act as ambient boundary conditions. If your Nusselt numbers are changing depending on which is where, that is a hint that your domain is not large enough.
If possible it's better to specify stagnation pressure than static pressure, since the stagnation pressure is more physically correct.
metmet likes this.
Old   April 3, 2015, 10:49
Default Thanks!
anonymous
Thank you LuckyTran.
Follow up question, and I apologize because I am largely self taught at Fluent and therefore there's quite a few gaps in my knowledge, are there boundary conditions that tell Fluent these lines are just conceptual and in no way affect the flow?
My thinking is this. Because I am only interested in the temperature distribution in my smaller domain, and the nusselt numbers on the surface of my cylinder,, I'll create a much bigger domain to encapsulate it, but still just look at the smaller domain.
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Import Fluent Mesh and Boundary Conditions BTU-RoRo CFX 3 July 23, 2010 15:20
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 07:18
