March 31, 2015, 03:53 |
Convergence Problem
Agung
Rep Power: 11 |
Dear all,
hey, i have a problem with my project about gas lift injection. My solution cant converged, the residual is increase. I decreased the under relaxation factor (especially for momentum value) after i realized the residual is increased. I also monitor the inlet static pressure, and it seems to be good. My solution is like the below picture, so, my question is, is it okay or not? http://postimg.org/image/dgy6iygrr/ http://postimg.org/image/iivzck3xl/ I will very appreciate any comment from you guys Thanks and best regards |
March 31, 2015, 23:48 |
Lucky
Rep Power: 66 |
Looks reasonable, as long as you didn't set the urf's to very small values. I would try to return the urf's back to the defaults to see if has any affect.
April 4, 2015, 00:06 |
Agung
Rep Power: 11 |
Thank you sir, i have increased the URF and nothing happens with the surface monitor, i think the solution has converged. Thanks for you help
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
