[Sponsors] | |||||
Rep Power: 14 ![]() |
hi,
From the solution data it is easy to obtain turbulent viscosity at each cell center or node.. In similar fashion, is there any other way to find the laminar viscosity? Thanks shivakumar |
Cees Haringa
Rep Power: 0 ![]() |
The laminar viscosity is an input parameter which you provide under materials.
you can plot it in FLUENT if you want, bu for newtonian fluids it's a constant which you added yourself. |
can u tell me how to plot it?
Rep Power: 19 ![]() |
The laminar viscosity doesn't appear to be available to plot within Fluent directly. You could save the laminar viscosity of each cell with User-Defined Memory and then plot this UDM (holding the laminar viscosity values). I'm puzzled as to why you'd want to plot a uniform field of values... filling the domain in CFD-Post with a colour would be a quicker method.
Cees Haringa
I can see how it might be useful to do make effective viscosity plots for non-newtonian fluids; for newtonian it doesn't make sense indeed.
Thanks for the reply
From udf it possible find the laminar viscosity at each....('e') Yes indeed. for Newtonian flows it does not make sense..For example, when it comes to the viscous sensor algorithm given by Tognaccini, Laminar viscosity does make sense in the region of boundary layer. D=1+(mu_t/mu_l) |
Cees Haringa
You could write a simple user defined function that stores the viscosity in a user defined memory. I think this should work:
#include udf.h
DEFINE_ADJUST(my_adjust,d)
Thread *t;
cell_t c;
thread_loop_c(t,d)
begin_c_loop(c,t)
C_UDMI(c,t,0) = C_MU_L(c,t)
end_c_loop(c,t)
Thanks for the reply.. I got it.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can a turbulent flow converge in laminar simulatio | KM | CFX | 7 | December 5, 2019 01:25 |
| Eulerian Modeling: Frictional Viscosity Help | meangreen | FLUENT | 1 | January 25, 2018 16:13 |
| [swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
| CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 11:22 |
| Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 07:13 |
