June 9, 2015, 09:10 |
Vacuum chamber
Gustavo
Rep Power: 10 |
I´m new with Fluent. I would like to simulate the flow behaviour of a mixture gas inside a vacuum chamber. The process is: the pumping (air) of the chamber from atmospheric pressure until 1 PA. After this pressure been achieved, there will be 20 gas inlet (2mm Diameter) and will inject a mixture of two gases (O2 and N2). Also will be an outlet where the gases will come out through the pump keeping the pressure in 1Pa. As far as I could understand, I can use the laminar model. But I could not make an Animation of the air pumping and consequently the gas mixtures inlet showing the behaviour of the gas flow in this condition from the inlet until the outlet. Could anyone one give me some hints? How I inform the Software that my Initial condition is the chamber full of air and then the pumping starts until achieve 1Pa? P.S. I´m dealing with a big chamber of 3m3 volume. Last edited by gustavosimiema; June 9, 2015 at 11:35. |
gas inlet, pumping, vacuum |
Modeling a vacuum chamber in Icepak | L093N | FLUENT | 2 | December 25, 2013 08:39 |
Vacuum chamber and choked flow simulation | matteo89 | FLUENT | 0 | September 17, 2013 04:26 |
Modeling a vacuum chamber in Fluent | sagila | FLUENT | 13 | November 2, 2012 07:27 |
Turbulence BCs for flow into vacuum chamber | eric.m.tridas | OpenFOAM Pre-Processing | 0 | December 20, 2011 13:18 |
Modeling sudden flow in Vacuum chamber | Sandilya Garimella | FLUENT | 0 | February 8, 2008 15:04 |
