accessing lift fore/drag force in UDF
Old   February 27, 2006, 23:03
Default accessing lift fore/drag force in UDF
changkiang
hi,everybody! i'm trying to access lift fore(or lift coefficient)/drag force(or coefficient) in UDF and i don't know how. by the way, i'm simulating flow over a single circular cylinder.
thanx in advance for ur response!
Old   March 1, 2006, 00:13
Default Re: accessing lift fore/drag force in UDF
changkiang
well, it came to me, i can just read the file saved cl-history!
Old   March 1, 2006, 06:51
changkiang
but i think it quite time-consuming, someone said lift and drag can be picked-up from fluent, but how?
can anyone help me?
thank u very much!
Old   March 1, 2006, 07:40
Dan
Not sure if it's what you're looking for, but you can use "monitor-force" to monitor the lift and drag coefficients after each iteration or time-step.
Old   March 2, 2006, 02:54
changkiang
thanx for responding. well, i'm programming a UDF and the lift(drag) force is used, then the easiest way to access it in UDF is?
Old   March 2, 2006, 03:05
changkiang
or how we can access the values( Reprot\Forces) in UDF DIRECTLY.
thanks
Old   May 11, 2015, 15:00
Shree
sarjerao is on a distinguished road
I also want same thing in my UDF! Did you solved that problem.
If yes, what you did to access lift/drag in udf.
sarjerao is offline   Reply With Quote
Force can not converge colopolo CFX 13 October 4, 2011 22:03
Saffman Lift Force: confused CFD_MAN FLUENT 5 September 9, 2010 04:51
Magnus lift force using UDF - urgent help please Angela Wang FLUENT 2 December 17, 2008 06:03
Urgently Need the code of Lift force and VM force Kai Yan Main CFD Forum 0 July 16, 2008 07:07
UDF for lift force on a bluff body sawa FLUENT 2 April 11, 2005 03:06
