March 30, 2016, 16:52 |
Fixed tangential velocity in a cell zone
I want to make zero tangential velocity and other components untouched (none). Initially, I got a warning " Some velocity components in the local coordinates are not fixed. Please correct your input for cell zone 2" I ignored it and ran the simulation and got convergence issues. Please give me some suggestion in order to create zero tangential velocity in a cell zone. Thank you F.Y.I I have an interior face in the domain and it doesn't not have no slip condition. I'm trying enforce this by adding zero tangential velocity. |
March 30, 2016, 18:10 |
Rep Power: 18 |
How are you adding zero tangential velocity to a non-no slip wall? If you want to have a slip wall, you could use Wall Motion > Stationary Wall and Shear Condition > Specified Shear with zero shear stresses.
March 30, 2016, 18:55 |
Thank you for the reply. I have a interior face (situated at the interface of two domains). I want no slip condition at this interior face. If i change this in to a wall, I wont get the flow in to the other domain. Cheers
March 30, 2016, 18:57 |
Also, I have one cell thickness layer which is separate zone. In this zone I can fix the velocities. This is the method I have used in the simulation.
June 3, 2016, 10:00 |
Fixed Velocity in cell zone
johnr
Rep Power: 9 |
I am trying to fix the axial velocity in a cell zone but getting error of pressure divergence. I have tried everything but can't solve the problem. I am doing a 3D analysis of flow in two tanks connected by two pipes. One pipe has this small cylindrical cell zone(made by slicing operation) in which i am trying to fix the velocity. Putting a x momentum source term is working perfectly fine though. Please help! Last edited by Johnr; June 3, 2016 at 10:05. Reason: missed to write something |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 12:25 |
Cells with t below lower limit | Purushothama | Siemens | 2 | May 31, 2010 21:58 |
fixed Value for cell Zone | Chrisi1984 | OpenFOAM | 0 | May 27, 2010 03:39 |
