Increasing Shock Resolution
Old   March 7, 2022, 17:24
Default Increasing Shock Resolution
mmmaada00 is on a distinguished road
I have simulating a oblique shockwaves in a channel with a terminating shock with the aim of analys8inig the total pressure loss. However, the resolution of the shock(s) in the solution is very poor (I have included an image below).
I believe the mesh is sufficiently fine and has a high cell count with a good element quality. I am also using a density based solver.
Could anybody offer help as to what I may do to fix this issue?
Thank you.
mmmaada00 is offline   Reply With Quote
Old   March 7, 2022, 23:51
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
looks like the mesh is an issue
may be inlet part of your mesh
on the other hand may be your solution is not converged
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Inviscid Supersonic Wedge Tutorial similar mesh but different shock resolution? r.s. SU2 2 May 13, 2020 19:02
Decreaseing error tolerance of the pressure solve when increasing grid resolution ? zx-81 Main CFD Forum 10 August 24, 2019 10:43
[Other] Increasing interface resolution with adaptive meshing LauraL OpenFOAM Meshing & Mesh Conversion 1 May 9, 2017 10:40
Increasing mesh resolution yields big difference in pressure? Wizze OpenFOAM Running, Solving & CFD 2 September 26, 2014 08:15
Increasing resolution of mesh in GAMBIT Vidya Raja FLUENT 1 October 10, 2005 01:48
