March 7, 2022, 17:24 |
Increasing Shock Resolution
Rep Power: 4 |
I have simulating a oblique shockwaves in a channel with a terminating shock with the aim of analys8inig the total pressure loss. However, the resolution of the shock(s) in the solution is very poor (I have included an image below).
I believe the mesh is sufficiently fine and has a high cell count with a good element quality. I am also using a density based solver. Could anybody offer help as to what I may do to fix this issue? Thank you. |
March 7, 2022, 23:51 |
Alexander
Rep Power: 34 |
looks like the mesh is an issue
may be inlet part of your mesh on the other hand may be your solution is not converged
best regards ****************************** press LIKE if this message was helpful |
Inviscid Supersonic Wedge Tutorial similar mesh but different shock resolution? | r.s. | SU2 | 2 | May 13, 2020 19:02 |
Decreaseing error tolerance of the pressure solve when increasing grid resolution ? | zx-81 | Main CFD Forum | 10 | August 24, 2019 10:43 |
[Other] Increasing interface resolution with adaptive meshing | LauraL | OpenFOAM Meshing & Mesh Conversion | 1 | May 9, 2017 10:40 |
Increasing mesh resolution yields big difference in pressure? | Wizze | OpenFOAM Running, Solving & CFD | 2 | September 26, 2014 08:15 |
Increasing resolution of mesh in GAMBIT | Vidya Raja | FLUENT | 1 | October 10, 2005 01:48 |
