Natural convection in the spent fuel pool
Old   April 21, 2015, 11:03
Default Natural convection in the spent fuel pool
Audrius
Audrius is on a distinguished road
Hi everyone,
I have question. I'm trying to simulate natural convection in the spent fuel pool. For example I have a box which dimensions is: lenght and width 6,0 m, height 11,0 m.
Setup in Fluent 14.0 is:
General:
Solver - pressure-based
Time - steady
Gravity - Z axis -9.81
Models:
Energy - ON
Viscous - Standart k-e, Standart Wall Fn
Materials:
Fluid: water (boussinesq model 998,2 density; Cp 4182; Thermal Conductivity 0,6; Viscousity 0.001003; Thermal expansion coefficient 0,0002)
Cell Zone Conditions -> Edit -> Material name - water-liquid
Boundary Conditions (to types of wall: one wall heat - temperature 500K; others walls are only convection (Heat transfer coef. 2.5; Free stream temperature 293); OPERATING COUNDITIONS: operating pressure 101325 Pa, operating temperature 301K.
Solution methods: Scheme - simple; Gradient - Least Squares Cell Based; Pressure - Body force weighted; Momentum, Turbulent Kinetic Energy, Turbulent dissipation rate, energy is first order upwind
Solution Initialization - hybryd initialization
Run calculation - 1000 iterations
First question is - thats wrong with pressure? In the bottom of pool preassure should be about 2 bar.
Second queastion is - what way the water can be heated uo to 226 K (Water boiling near 2 bar pressure is about 110-120 Celsius and water can't be the biger temperature than ~110-120 Celsius?
Thank You!
Audrius is offline   Reply With Quote
Old   April 22, 2015, 12:35
Audrius
Please, help...
Old   June 14, 2015, 07:05
Shane
sircorp is on a distinguished road
Originally Posted by Audrius View Post
Hi everyone,
General:
Time - steady
Models:
Energy - ON
Materials:
Thank You!
It is a case of Forced Convection Cooling. Pressure is with reference to Injection Point. (Similar to a pre-pressurized thank). set the reference pressure (in operating conditions) what ever is the pressure at the bottom of the cooling pool)
(I am not a expert but) Problem what I can see it your meshing zixe ? Such a large system, you need a massive computer to even create Meshing and months to process the modelling.
Good Luck
Shane
sircorp is offline   Reply With Quote
Old   June 14, 2015, 09:46
Audrius
Dear Sircop,
I have a very powerful compute cluster, so the mesh for my pool is about 30 million cels. Now my model looks like this:
My model is closed domain, so there is not the inlet and outlet pipes and the preasure in the operational conditions are selected like this:
By the way, maybe You have Forced Convection Cooling or Pre-pressurized tank tutorials?
Kind regards,
Audrius
Heat transfer between two closed cavities with natural convection Czarulla FLUENT 2 August 5, 2020 12:36
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 11:44
natural convection problem with radiation jorien CFX 0 October 14, 2011 09:26
Natural Convection with heat generation krishnachandranr Main CFD Forum 0 July 28, 2009 04:22
Coupled vs Seg - Natural vs. Forced Convection Alex Siemens 5 December 12, 2007 04:58
