Which Radiation Model to choose in hot gas flow
Old   May 30, 2015, 02:12
Default Which Radiation Model to choose in hot gas flow
Ravi Agrawal
abc197 is on a distinguished road
I am simulating simple gas flow through pipe, where inlet gas temperature is around 1400 K. I have to consider radiation from gas to inner pipe wall along with convection. Outer wall to atmosphere is also to be included. Which radiation model among Rosseland, P1, DTRM, S2S and DO will be most appropriate in this case and why?
(I am sure to notice significant change in isotherms when radiation is included instead of just convection.)
Thanks in advance...
abc197 is offline   Reply With Quote
Old   June 14, 2015, 06:40
Ravi Agrawal
Anybody up for this?..Can scattering be neglected..I got unrealistic surface heat transfer coefficients, when using DO model..I used assumed values of radiation properties of gas and wall. Also , did not select Do-energy coupling. Will these things make some differences?
fluent, gas flow, pipe, radiation models
Radiation Modeling Chris89 CFX 20 August 14, 2014 07:51
What model of turbulence choose to study an external aerodynamics case raffale OpenFOAM 0 August 23, 2012 05:45
Coupling Radiation with Flow model tongx051 FLUENT 0 October 22, 2011 16:03
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Transient natural gas flow description Leila FLUENT 0 November 29, 2003 16:06
