June 4, 2015, 03:09 |
Dynamic mesh : Oscillating cylinder
Paul
Rep Power: 10 |
I am a beginner in Fluent 15.0 and I am trying to realize the modelisation of a flow through an oscillating cylinder. I don't have any problem loading the UDF describing the movement of the cylinder but I can't see anthing with "Preview Mesh Motion" or even "Display Zone Motion" in the Dynamic Task page. I am using Smoothing and Remeshing as Mesh Methods. Maybe the problem comes from the UDF I am using : #include "udf.h" DEFINE_CG_MOTION(pis,dt,vel,omega,time,dtime) { Thread*t; face_t*f; real A=1; real freq=1; real pi=3.14159265; real w=2*pi*freq; real v=A*w*sin(w*time); /*reset velocities */ NV_S(vel,=,0.0); NV_S(omega,=,0.0); if (!Data_Valid_P()) return; t=DT_THREAD(dt); vel[1] = v; } I don't know if it is related but i am also not able to edit the Function Hooks. This problem may have been already explained in this forum but I couldn't find any explanations. Does someone have an answer ? Thanks ! |
June 4, 2015, 07:22 |
alireza
Hi
1- Did you use complied or interpreted? you should use compiled. 2- Did you set solver to unsteady condition? you UDF is right but you can comment this lines (its not necessary). /*reset velocities */ NV_S(vel,=,0.0); NV_S(omega,=,0.0); if (!Data_Valid_P()) return; t=DT_THREAD(dt); -------------------------------------- if you did (do) these steps, you have to see mesh motion. |
June 8, 2015, 03:23 |
Paul
Rep Power: 10 |
Hi alireza_b,
Thanks for your answer. Unfortunately, I already used compiled UDF and the solver was in unsteady conditions. Therefore, I still do not know how to see the mesh motion. When I use "Preview Mesh Motion", the same calcul is done all over again without changes in the meshing. Isn't there other options that have to be activated to display the mesh motion ? Thanks. |
June 8, 2015, 14:00 |
alireza
Hi
what is your time step? Could you increases it and see what happens? maybe your time step is too low, so it takes time a lot to change in cylinder position. I suggest you calculate the frequency and then calculate period and use this time step. Dt=Period/2000 I saw it a lot in many paper by Fluent. |
June 9, 2015, 15:18 |
Paul
Rep Power: 10 |
Thanks for your advices. It turns out I just had to launch the simulation without the moving cylinder before adding the dynamic mesh and the movement based on the UDF (maybe this was evident for anyone else). I can finally see the cylinder moving.
Now, I am having trouble with the position of the cylinder during the simulation. Even when I set his gravity center at the coordinates (0,0) in the Dynamic Mesh options, it oscillates with another origin during the simulation. But maybe it is just a small problem to solve. Anyway, thank you for your answers. |
May 12, 2017, 08:01 |
oscillating cylinder dynamic mesh
rihen full
I try to solve a flow past a oscillating cylinder between paralel wall. I would like to make cylinder goes up and down. But I cannot prepare udf file for cylinder motion. Can you help me?
Dynamic mesh using profile | sanjeetlimbu | Fluent Multiphase | 3 | April 19, 2018 09:49 |
dynamic mesh problem with Oscillating B.C. | Haier | OpenFOAM Running, Solving & CFD | 0 | September 25, 2014 06:47 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
