calculationg heat transfer coefficient in a packe bed
Old   June 17, 2015, 05:55
Unhappy calculationg heat transfer coefficient in a packe bed
sarah
sarah l is on a distinguished road
I am supposed to simulate heat transfer in a packed bed of fuel spheres. I use FLUENT 14.5. in literature, Heat transfer coefficient is about 20000, but in Fluent , Wall function heat trans coef , it is 300.
I know, I should use the following formula to calculate HTC:
h = heat_flux / (T(z) - Tbulk(z))
but there is a problem related to heat flux;
I don't know how to find it in fluent.
should I go the following path to find heat flux?
report>fluxes>heat transfer rate> inlet-outlet
Thank you
sarah l is offline   Reply With Quote
Old   June 18, 2015, 05:56
liusuanyatong
liusuanyatong is on a distinguished road
I think you are right.But I'm not sure.I have some question about heat flux.
liusuanyatong is offline   Reply With Quote
Old   June 18, 2015, 13:24
shirin patil
shirin3151 is on a distinguished road
Then how will find the heat flux for constant wall temperature to find the nusselt number
shirin3151 is offline   Reply With Quote
Old   June 18, 2015, 14:17
sarah
it will work for constant wall temp, and after you calculate heat flux you can obtain Nu simply by using following eq:
Nu= ( heat_flux/T-T_wall) *L/K_fluid
Heat flux and Heat transfer coefficient sakil2k3 FLUENT 4 July 5, 2015 15:07
Heat Transfer Coefficient AndBra FLUENT 2 June 4, 2013 15:35
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Heat Transfer Coefficient los OpenFOAM Running, Solving & CFD 5 January 31, 2010 17:44
