June 29, 2015, 15:05 |
negative mass flow rate in pressure outlet
Piyush Aras
Rep Power: 10 |
I am modeling a multiphase system of water and air in which only water is leaving from my pressure outlets . .
I have getting negative mass flowrates at my pressure outlets. Is it correct that it is treating mass flow rate as vector quantity or something and I should take the magnitude or it is conceptually wrong and water is instead entering through my outlet. |
June 30, 2015, 09:05 |
Rep Power: 26 |
Fluent uses the inward normal.
So a negative mass flow at a boundary means that mass is leaving your system, and a positive mass flow means that mass is entering your system. |
June 30, 2015, 11:41 |
Piyush Aras
Rep Power: 10 |
Yeah that's what my doubt was.
thank you for clearing my doubt. |
December 9, 2018, 07:06 |
Rep Power: 7 |
hi, I am simulating a channel flow having the periodic inlet in fluent and mass flux rate is negative, is that right answer? and is there any effect of this on Reynolds number?
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Match mass flow rate with inlet pressure and outlet pressure | vut | Main CFD Forum | 9 | February 21, 2014 18:07 |
Problems in pressure when using mass flow rate outlet | rafiktharwat | CFX | 11 | January 2, 2014 17:21 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 00:09 |
Convergence problem with target mass flow rate | ADL | FLUENT | 2 | May 29, 2012 21:11 |
