C functions in UDF Macro
Old   July 1, 2015, 08:32
Default C functions in UDF Macro
jacek is on a distinguished road
I have a problem with compiling C function in UDF. It seems that Flueent does not accept C functions. For instance, a short code:
DEFINE_ON_DEMAND
int imin(int, int); // line 1
int imin(int n, int m) // line 2
So, Fluent doesn't accept the function definition (line 2): "syntax error: missing ';' before '(' ". So, it treats the definition as a variable declaration. Remove "int" befor "init", it yields next problems, untill you remove the whole function definition.
What is the difference in the function syntax in pure C and the UDF?
jacek is offline   Reply With Quote
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
functions in UDF Lucy FLUENT 4 April 14, 2011 16:41
some UDF macro duaiduaihu FLUENT 0 July 8, 2009 23:00
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
DEFINE_DPM_OUTPUT macro UDF HELP Puneet FLUENT 3 November 28, 2003 10:55
