Basics for a multi flow problem
Old   July 14, 2015, 03:14
Default Basics for a multi flow problem
PCFD is on a distinguished road
I do want to investigate a multi-fluid problem which means I do have to "pipes" with Cl2 and HCl and I want to simulate the mixing of those two streams. I am not interested in particle-tracking and therefore an Euler-Euler approach would be my choice.
My questions:
1) Would you rather recommend to run this in CFX or in Fluent? I expect local Mach numbers of ~0.6 - 0.7.
2) Could you recommend a specific turbulence model which works suitable/stable for multi phase problems? Is is legitim to use the BSL model in CFX? ( I know this is probably a very hard question and I do not expect a general answer. But maybe you can share some of your experiences.... and warn me if it does not make sense to use XXXX! )
Thanks a lot!
PCFD is offline   Reply With Quote
flow past abdominal aorta. Complex BC problem. ziemowitzima OpenFOAM Running, Solving & CFD 1 July 26, 2022 05:12
Having Problem solving 2D supersonic flow around a plug nozzle chrislloyd FLUENT 7 July 22, 2015 13:09
Multiphase flow problem icedou FLUENT 6 July 10, 2005 02:52
transient compressible flow problem (urgent plz) jehanzeb FLUENT 5 August 3, 2004 08:04
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
