July 21, 2015, 14:37 |
Washcoat factor
Amit Kunte
Rep Power: 10 |
Hi all,
Can anyone please explain what the where the washcoat factor comes into play in the equations in the fluent solver. I only know that the washcoat factor is ratio of catalyst surface area to reactive wall area. I am running a platinum catalysed propane combustion simulation and when i increase the washcoat factor above 1 the reaction rate and the associated temperature of reaction actually decrease and vice versa with decreasing the factor. Does anyone has any idea about this? |
August 6, 2016, 10:24 |
vlg
Rep Power: 17 |
Dear Amit!
Yes, it seems odd that the temperature and reaction rate decrease when increasing the washcoat factor unless you simulating endothermic reaction. Does the temperature increase with the catalyst length in any case? Are you sure these are not convergence issues? |
August 16, 2016, 11:46 |
vlg
Rep Power: 17 |
Now I definitely have run into the same issues during my project!
I think it may be a bug in "heat of surface reaction" option. Compare to: http://www.cfd-online.com/Forums/flu...actor-bug.html 1) The heat of surface reaction depends on kinetics at the same conversion level of all species (that is WRONG). I could have 30 or 130 K adiabatic heat rise when changing surface reaction rate constant (at 100% conversion at both case). 2) Washcoat factor increase decreases the adiabatic heat rise (at the same 100% conversion level). Affect at least v162 both in 2D and 3D. |
March 20, 2017, 07:41 |
Catalytic combination project
Shahid waqas
sir i have project on catalytic recombination of hydrogen and oxygen. can you please help me i have set the reaction but reaction is ocuuring problem is that i could not achieve the temperature profile??
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Lets talk about relaxation factor optimization | chriss85 | OpenFOAM Running, Solving & CFD | 35 | June 21, 2019 09:54 |
Washcoat Factor Bug | koad | FLUENT | 1 | July 13, 2015 12:49 |
[Gmsh] Gmsh and element size factor | msarkar | OpenFOAM Meshing & Mesh Conversion | 0 | May 2, 2011 02:55 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
