Questions when applying sliding meshes
Like Tree1Likes
  • 1 Post By ghost82
Old   July 24, 2015, 05:17
Default Questions when applying sliding meshes
Felix
didiean is on a distinguished road
Hi everyone,
I am trying to do a simulation on a rotating wind turbine.
I made up a cylinder to realize the rotating of the rotor, using sliding mesh method.
But after I define the interfaces for the boundary. Zero-area walls come out as boundaries of the interface. The "walls" doesn't appear when displaying the mesh. But the results do show their influences.
Is there a method to change the wall to interior?
Or is there any other method to fix this?
Thank you.
didiean is offline   Reply With Quote
Old   July 24, 2015, 08:34
ghost82's Avatar
Rick
ghost82 will become famous soon enough
That walls should be generated if you create an interface (interface 1) from surface 1 and surface 2 and they do not overlap 100%.
If you create 2 perfectly overlapping surfaces you can see the "walls" in boundary condition panel but they don't influence your simulation.
Try to plot that surfaces: if something is displayed then go back to pre-processing and create perfectly overlapping surfaces for your interfaces.
Daniele
jamalf64 likes this.
Google is your friend and the same for the search button!
ghost82 is offline   Reply With Quote
Old   July 26, 2015, 20:46
Felix
Thanks for your reply.
The two interfaces do fully overlap with each other, and the walls appearing in the boundary list could not be observed in the mesh display.
The generated zero-area wall seems like a "wall line". As when I view the velocity at that exact line position, the velocity is zero.
Daniele
Looking for the tutorial "Using Sliding Meshes" faycal2013 FLUENT 0 November 8, 2014 09:26
3D sliding meshes lml FLUENT 6 September 9, 2014 07:16
Hex and Tet meshes - simplefoam comparison danvica OpenFOAM Running, Solving & CFD 10 January 4, 2013 01:18
HAWT, should we use sliding meshes? or the UDF? f0208secretx FLUENT 11 February 19, 2012 05:58
sliding meshes betakv OpenFOAM 1 August 12, 2009 12:34
