August 10, 2015, 09:05 |
Finite rate chemistry
sunil
Hello Every one,
I am accounting reactions with finite rate chemistry model. for calculating rate constant i am using arrhenius equation. I struck with the input units and then i refereed fluent theory guide. For SI unit system, whether the following units are correct for fluent input. Activation energy = [J/k mol] Temperature exponent = [dimensionless] Gas constant (R) = [j/k mol] Pre-exponential factor 1st order = 1/s 2nd order = m3/kg s and what is the unit for 3rd order reaction. |
units of rate constant |
Finite Rate Chemistry Setup for Hypersonic Flow | AdeeMij | FLUENT | 22 | July 11, 2017 10:28 |
How to use Eddy Dissipation rate only When using Finite rate/Eddy Dissipation model | Dziyad | FLUENT | 2 | February 19, 2014 17:25 |
Finite chemistry rate and multiple step | marazn | CFX | 0 | August 28, 2013 06:11 |
Laminar Finite Rate Chemistry - Pre-exponential | Arun | FLUENT | 7 | August 30, 2012 07:09 |
Combustion-Laminar finite rate model | Shankar | FLUENT | 0 | January 15, 2004 22:51 |
