February 27, 2015, 03:53 |
Dynamic stall on an airfoil
Anthony McCarthy
Rep Power: 11 |
hopefully a simple question for somebody to answer. I am trying to use fluent to predict stall angle and post stall cl/cd. I have been trying to run a 2d transient problem, both with DDES transition SST and the pressure and density models. i am not yielding the results i would like to achieve. I am wondering if this is because i need to simulate this as a 3D problem? I have very limited computational power and am running the student version of fluent at university. Please if you can help or need any more information, please get in touch even if it just ideas i have been stuck for quite a while and do not have many resources at my university for CFD and no specialists. Thanks Anthony |
March 4, 2015, 10:22 |
Anthony McCarthy
Rep Power: 11 |
has anybody got any information to input?
March 18, 2015, 05:59 |
Erik Löfgren
Rep Power: 11 |
I don't know anything about the DDES model, but it should be possible with SST k-omega for instance. However, in the post-stall regime, the problem is highly unsteady. There is likely to be periodic vortex shedding requiring a fine mesh and small time step. Also, since cl and cd are surface forces it is important to properly resolve the boundary layer around the airfoil to get good accuracy. If possible, make sure that the y+ is around 1 in your first cells at the airfoil. And then you also need to make sure that the boundaries are far enough away from the airfoil, so that the flow is fully developed before it reaches the outlet.
Technically, there is to my knowledge no reason why this would be more difficult to simulate in 2D than in 3D so I think you should do fine. But note that you will probably not find steady solutions in the post-stall regime, so in order to get good statistics (mean drag etc.) you will probably have to do quite long simulations. |
March 18, 2015, 07:59 |
Anthony McCarthy
Rep Power: 11 |
Hi Erlofg,
Thank you for your response. I have quite a few questions that i believe you may be able to answer if you are willing to help? Do you mind if i pose these questions to you? Ideally it would be best to have a live chat if possible and then i can post the discussion on the forum to also help benefit other users Anthony |
March 18, 2015, 10:04 |
Erik Löfgren
Rep Power: 11 |
I'm not really an expert per se in these matters, but ask away and we'll see what I can answer. It's better for me to take it here in the forums so that I may take some time to consider the answers...
August 11, 2015, 12:27 |
Rep Power: 12 |
Basically, you can't perform a DES in a 2d problem, because the LES part of your DES won't make any sense, since turbulence is 3d. Then, of course you have to use the 3d solver.
August 11, 2015, 12:38 |
#7 | |
Lucky
Rep Power: 66 |
2D DES/LES/DNS can be computed but the results are limited to simulating this degenerate 2D turbulence state and should not be used to even try to describe what happens in 3D turbulence. |
August 11, 2015, 12:42 |
Rep Power: 12 |
Yes, but the problem here is an airfoil in post stall, if you hope to catch something like that with a 2D DDES, be my guest.
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
sliding mesh ? airfoil dynamic stall? | xiaomi | FLUENT | 2 | March 18, 2013 05:42 |
How to set the dynamic stall convergence criterion of airfoil? | shlgzz | FLUENT | 0 | January 10, 2013 21:45 |
dynamic stall simulation over an airfoil | mleahy | FLUENT | 0 | October 9, 2009 12:15 |
