porous media combustion
Old   July 27, 2009, 11:22
Default porous media combustion
zubair
zuby is on a distinguished road
Hii Fluent,
I am modelling combustion through a porous media burner. i am using 2 porous media with porosity of 86% and 84% respectively. I used species transport with volumetric eddy dissipation reaction model to account for combustion. n butane-air is the mixture that flows through the porus burner. However my fluent simulation is resulting in very high temperature of the magnitude of 5000K below the porous burner regon even though i have not patched temp for initiating ignition in the domain. hence i divided the domain into 3 regions. one is the fluid region without any reaction, 2nd is the porous region without any reaction and the 3rd fluid region with reaction activated. even though i could successfully initiate combustion at the top surface of the burner, the temperature are very high and unrealistic. Also in both cases i am not able to converge my results even after 20000 iterations. k-e is the turbulance model i have used. Kindly suggest me to model the porous media combustion. (also i would like to check the use of porous jump- is it the interface b/w 2 porous media?). thanks in advance
zuby is offline   Reply With Quote
Old   September 11, 2014, 15:44
Ankit Shukla
ankitshukla is on a distinguished road
hi zuby can u send me a file in which all steps are mentioned to draw porous media . actually i am new student in this feild and i am new in porous media combustion.if u sent me it is very gratefu
ankitshukla is offline   Reply With Quote
Old   August 31, 2015, 04:42
Nirmal
nirmalms90 is on a distinguished road
I am facing problem in modelling and simulating premixed porous media combustion in fluent/CFx... It would be really helpful if someone can share the procedure to be done for simulation
nirmalms90 is offline   Reply With Quote
combustion in porous media burner zuby ANSYS 0 July 27, 2009 02:26
combustion in porous media Julia FLUENT 1 May 20, 2003 12:23
Laminar combustion in porous media Mashihu FLUENT 4 May 10, 2003 20:08
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
combustion in porous media Seaspace Main CFD Forum 1 November 29, 2000 11:16
