Use of Wall Function Heat Transfer co-efficient |
September 4, 2015, 04:02 |
Mochibaru
Rep Power: 11 |
Hello Everybody,
I am currently using Enhanced Turbulence model with K-Epsilon standard wall treatment?I want to calculate the Convective heat transfer co-efficient across the wall. I have Two queries for it: 1.Whether i should use the Wall Function Heat Transfer Coefficient or Surface Heat Transfer co-efficient? 2.As there is very fine mesh in vicinity of wall so i used Enhanced wall function.SO if it is better to use Wall Function HTC for fine mesh or not? Your Kind suggestions will be highly appreciated. Thanks |
September 8, 2015, 01:02 |
Lucky
Rep Power: 66 |
The surface heat transfer coefficient is most likely the one you are after. The surface heat transfer coefficient is the heat flux divided by the difference between local wall temperature and the reference temperature. Don't forget to specify the reference temperature (in the reference values pane).
The wall function heat transfer coefficient is calculated in terms of the dimensionless inner variables (u*, and T*). |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Heat transfer BC at wall- why need wall thickness? | Julie | FLUENT | 7 | February 3, 2012 21:41 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
