Fluent Capability for solving Polyhedral Mesh
Old   September 16, 2015, 12:43
Default Fluent Capability for solving Polyhedral Mesh
jsm
JSM
jsm is on a distinguished road
Hello All,
I found an beta feature for polyhedral mesh generation in fluent-meshing 16.2 version. It looks like, we can get good quality than tetra mesh for complex geometries.
My question is, Is fluent capable to solve with polyhedral elements robustly? Anyone studied about results difference for tetra and polyhedral mesh.
Your comments are appreciated!
With regards,
JSM
jsm is offline   Reply With Quote
Old   September 16, 2015, 13:57
Antanas is on a distinguished road
Originally Posted by jsm View Post
Hello All,
If I am not mistaken, Fluent can convert tetra meshes to polyhedral and solve on 'em for a long time.
Antanas is offline   Reply With Quote
Old   September 16, 2015, 14:32
jsm
JSM
Yes. It is available for long time. But I am not sure, solver and discretization equations can handle polyhedral elements and produce accurate results. Because of this, I hesitate to use polyhedral elements til now.
If someone did correlation study with tetra and polyhedral mesh, then it will be interesting to discuss.
With regards,
JSM
Old   September 16, 2015, 18:40
Arjun
arjun will become famous soon enougharjun will become famous soon enough
Do yo u know any code that can do accurate polyhedral treatment?
arjun is offline   Reply With Quote
Old   September 16, 2015, 23:12
jsm
JSM
I think, Star CCM+ has polyhedral element treatment. But I don't know about Fluent. That is what I would like to know.
With regards,
JSM
Old   September 16, 2015, 23:18
From Fluent Manual:
When in solution mode, Fluent allows you to simulate the following:
- 2D planar, 2D axisymmetric, 2D axisymmetric with swirl (rotationally symmetric), and 3D flows
- Flows on quadrilateral, triangular, hexahedral (brick), tetrahedral, wedge, pyramid, polyhedral, and mixed element meshes
- Steady-state or transient flows
Dou you have doubt that this is true?
Old   September 17, 2015, 00:45
Lucky
As others have mentioned, Fluent has supported the ability to solve polyhedral meshes for a long time and even has built-in support to convert tetrahedral mesh to a polyhedral one.
One of the niceties of having an unstructured solver is that the solver doesn't care what the grid geometry is. Unfortunately, for the same reason, it's difficult to implement higher order discretization schemes and that's why you're typically limited to 1st or 2nd order upwind schemes. The only things that would affect the robustness are things like cell skewness or area-to-volume ratio, but those problems are general and apply to all grid types. In other words, it really doesn't matter whether your cell is hexahedral with 6 faces or 5 faces or 7 faces or 12 faces.
Old   September 17, 2015, 10:26
jsm
JSM
Thank you for comments - Antanas & LuckyTran. I understood your points.
Have you used polyhedral elements and compared the results?
With regards,
JSM
Old   September 17, 2015, 11:08
Have you used polyhedral elements ...?
Only in CFX
Old   September 17, 2015, 12:22
Arjun
Fluent can also treat polyhderal and results will be no worse than ccm. There is nothing special in ccm that fluent does not have for polyhedrals.
Old   September 17, 2015, 12:23
jsm
JSM
Originally Posted by Antanas View Post
Only in CFX
How it is worked for you? Do you got accurate results than tetra mesh? And do you compared with test?
With regards,
JSM
Old   September 17, 2015, 12:29
jsm
JSM
I never had chance to compare Fluent vs ccm+ with polyhedral mesh. But I should try polyhedral mesh in fluent and compare with test data.
With regards,
JSM
Old   September 17, 2015, 12:55
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
Yes, Star CCM+ has polyhederal element treatment in it. in ccm the mesh elements it have are trimmer and polyhederal and the convergence time for poly mesh is less when compared to trimmer and with somewhat better flow results. but its still a debatable topic, with type of CFD problems one is dealing.
Regards,
Bharat
chapter 3:
-crossing the threshold-
Bharatt is offline   Reply With Quote
Star CCM Overset Mesh Error (Rotating Turbine) thezack Siemens 7 October 12, 2016 12:14
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Polyhedral mesh has many more celle than standard mesh klausb enGrid 2 March 16, 2015 09:01
Polyhedral mesh in Fluent Shri FLUENT 3 August 22, 2007 05:31
