Heat Transfer Through a Porous Medium
Old   September 28, 2015, 11:52
Default Heat Transfer Through a Porous Medium
vanilla is on a distinguished road
Hello
I am trying to model forced convection heat transfer through a porous medium.
I have a vertical cylinder with a constant surface temperature (because I don't know the heat flux) and I defined a porous zone with the calculated viscous and inertial resistance factors (from experimental data). The porosity of the medium was also measured.
When I compute the total heat transfer rate across the outlet at the top it gives me a large negative number. But when I turn the porous zone off I get a realistic positive heat transfer rate for forced convection. What am I doing wrong?
I am using the thermal non-equilibrium model with an estimated interfacial area density (for now) and the heat transfer coefficient from my experiment.
vanilla is offline   Reply With Quote
porous media
Heat Transfer in porous media debabrata.mahapatra CFX 2 July 17, 2014 16:59
Porous domain:Interfacial area density and heat transfer coefficient l.te CFX 2 May 17, 2014 23:45
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Heat Transfer mechanisms tafaugl CFX 1 November 7, 2012 18:46
Heat Transfer in Porous Medium eryan STAR-CD 0 September 28, 2010 13:14
