DO radiation model
Old   October 19, 2015, 11:25
Question DO radiation model
Nima
nima_nz is on a distinguished road
I have an enclosure with one semi-transparent wall and all other walls are opaque. After the code converged, the heat flux results show that all the negative heat flux on the semi-transparent wall, when I have the solar load, and convective boundary condition with 30 C outdoor condition and all other walls are set to zero heat flux. So, when the temperature of the room should be higher that outdoor temperature, it's less.
I appreciate that if you help me.
nima_nz is offline   Reply With Quote
Old   October 20, 2015, 02:46
Svetlana Tkachenko
Svetlana is on a distinguished road
Hi nima_nz. Is it a steady state simulation? Do you have any past research papers which investigate a similar configuration?
Svetlana is offline   Reply With Quote
Old   October 20, 2015, 10:24
Nima
Yes, it is a steady simulation. I didn't find a paper which is exactly like my model, but there is some research which can be helpful, like:
http://www.sciencedirect.com/science...60148113005417
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
problem in glass radiation model (DO model) wunan805 FLUENT 0 October 10, 2012 06:06
Help: Radiation model MANOJKUMAR FLUENT 4 November 24, 2005 03:45
definition difficulty-->DO radiation model Harry Qiu FLUENT 0 March 29, 2001 10:19
