November 6, 2015, 13:57 |
Importing Temperature Data
Georgia (GA)
How do you import temperature data as a boundary condition?
Take a 2D plate for example... How do you import temperature data as an edge boundary condition and how would you import the entire temperature field? For my case, I have the data in a .csv file as a function of position, T(x,y). I could convert it to whatever format possible... but is it possible to import this data as a starting point? Or take part of the data and import it as a boundary condition? |
November 6, 2015, 19:38 |
Lucky
Rep Power: 66 |
You can write the data to a properly formatted text file of x,y coordinates followed by temperatures. Then read this file as a profile. You will then be able to select the profile as a boundary condition or an initial condition. See section 6.6 in the Fluent User's Guide for details.
import data, temperature field |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
Importing Text data Into StarCCm+ | nithish | STAR-CCM+ | 3 | May 5, 2015 04:57 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
Wall temperature data in helical pipe! | Wael | Siemens | 3 | November 1, 2014 10:42 |
importing vertex data | Mattis Voss | FLUENT | 2 | November 4, 2005 01:12 |
