Dynamic mesh - smoothing
Old   November 20, 2020, 16:41
Default Dynamic mesh - smoothing
flashpointer is on a distinguished road
can someone show me a direction how can handle my dynamic mesh motion?
its only a small simplified part with motion profile but for my FSI modell the separation should be the same. During the FSI interaction the top surface of the gap also deformint so the layering method will wont work. The small gap at the end will be 20-50 times higher as at the beginning. The problem is that the mesh deformation is far from consistent:at the far side its almost negligible. I played hours with the smooth settings but without any succes. The sweep method mesh should be kept.
flashpointer is offline   Reply With Quote
dynamic mesh;
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 05:02
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 22:35
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 15:40
