December 18, 2015, 13:09 |
Fluent 3D pipe flow
I have created a 3d pipe flow problem for water in Fluent and solved it setting the flow to laminar, i am only interested the wall shear stress on one of the surfaces. When i solve i get a range of shear stresses, is it possible to get specific values?
the inlet velocity is 0.0005m/s and the outlet is pressure |
December 20, 2015, 11:28 |
#2 | |
vlg
Rep Power: 17 |
1) obtain a mean (min, max...) value over some zone (surface, plane, line) - use your zone/surface (appeared in boundary conditions) /plane (created through Surface -> Plane) / line (created through Surface -> Line) to calculate Reports/Volume Integrals (for zones) / Surface Integrals (for surfaces, planes, lines) of the variable that you want. How to create plane/line/point At specific point: you can use Surface -> Point to create point somewhere in your model, than calculate and monitor Integral value (Reports...) again. 2) you can print all values from a specific location (zone/surface/plane/line/point) to file (to postprocess in Excel, etc.): File -> Export -> Solution data... Use ASCII file type, choose the variable and location that you want. I prefer "Cell center" values (number of values agrees with number of mesh elements involved in the zones choosen). Then, press Write... and specify a filename with extension (e.g., 1.txt) and directory to save the file. Image below is an example how to export Static Temperature distribution from some surface (iwall) to file. Also, I attach link to .txt to see how ASCII export looks like. Hope, this would help! |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Nu values come up too high for cylindrical pipe turbulent flow | Onur10 | FLUENT | 7 | February 21, 2016 12:59 |
Fluent v15 multiphase flow b.c. failure Non-channel flow | mickjazz | Fluent Multiphase | 1 | September 22, 2014 06:41 |
Two-phase flow in a circular horizontal pipe | DmitryS | Fluent Multiphase | 0 | May 17, 2014 16:22 |
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) | florian_krause | OpenFOAM | 22 | June 13, 2013 21:25 |
