Fluent 3D pipe flow
Old   December 18, 2015, 13:09
Default Fluent 3D pipe flow
jamie7963 is on a distinguished road
I have created a 3d pipe flow problem for water in Fluent and solved it setting the flow to laminar, i am only interested the wall shear stress on one of the surfaces. When i solve i get a range of shear stresses, is it possible to get specific values?
the inlet velocity is 0.0005m/s and the outlet is pressure
jamie7963 is offline   Reply With Quote
Old   December 20, 2015, 11:28
Smile
vlg
villager is on a distinguished road
Umm, you may want:
1) obtain a mean (min, max...) value over some zone (surface, plane, line) - use your zone/surface (appeared in boundary conditions) /plane (created through Surface -> Plane) / line (created through Surface -> Line) to calculate Reports/Volume Integrals (for zones) / Surface Integrals (for surfaces, planes, lines) of the variable that you want.
How to create plane/line/point
At specific point: you can use Surface -> Point to create point somewhere in your model, than calculate and monitor Integral value (Reports...) again.
2) you can print all values from a specific location (zone/surface/plane/line/point) to file (to postprocess in Excel, etc.):
File -> Export -> Solution data... Use ASCII file type, choose the variable and location that you want. I prefer "Cell center" values (number of values agrees with number of mesh elements involved in the zones choosen). Then, press Write... and specify a filename with extension (e.g., 1.txt) and directory to save the file.
Image below is an example how to export Static Temperature distribution from some surface (iwall) to file. Also, I attach link to .txt to see how ASCII export looks like.
Hope, this would help!
villager is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Nu values come up too high for cylindrical pipe turbulent flow Onur10 FLUENT 7 February 21, 2016 12:59
Fluent v15 multiphase flow b.c. failure Non-channel flow mickjazz Fluent Multiphase 1 September 22, 2014 06:41
Two-phase flow in a circular horizontal pipe DmitryS Fluent Multiphase 0 May 17, 2014 16:22
setup problems - LES pipe flow with cyclic BC (1) and direct mapped inlet (2) florian_krause OpenFOAM 22 June 13, 2013 21:25
