December 19, 2015, 03:14 |
porous medium
alimaseer
Rep Power: 10 |
Hi ... im going to make a model which is a cavity filled with sand-silica as a porous medium ... the problem that stand to me is :
There is no sand-silica in database of materials that i use .. Is there any one can help me plz? |
December 20, 2015, 04:04 |
Kirill Sitdikov
ok, what u want? modeling flow via porous media? in this case u need experimental coefficient. read ansys help in 6.2.3 And other information u can find in book underground Hydromechanics or extraction of black oil
December 20, 2015, 10:57 |
#3 | |
vlg
You can create your own materials easily as well (just use any material under Materials -> Create/Edit -> type Solid, after changes press Change/Create and answer No - this will save your material not overwriting the existing ones in the case-file). Get the reference book or use online tables with material properties: molecular weight, density, thermal conductivity, heat capacity, etc. for SiO2. What properties you need depends on a study you do, but I listed the basic properties. Last edited by villager; December 20, 2015 at 10:59. Reason: add-on |
December 20, 2015, 10:59 |
alimaseer
Rep Power: 10 |
thank you ...
it is a metallic cube ( 0.3 * 0.3 * 0.3 ) m ... filled with sand - silica saturated with water and heated from below by constant heat flux.. Walls will be change to be wavy wall to find out how does that acting on temperature distribution |
December 20, 2015, 13:22 |
alimaseer
Rep Power: 10 |
thank you mr villager
1. i didn't find sio2 or quartz sand in default database 2. where can i add a material in this page http://store1.up-00.com/2015-12/1450633990771.jpg |
January 6, 2016, 14:57 |
Porous Medium
#6 | |
Ray
Rep Power: 10 |
Today is my first day here in this web site. I am also rather new to porous medium, did some tutorials and read text, but cannot figure out how I can do my task. Maybe you can help me? I have a porous cylinder. The cylinder is filled with gas. Outside the cylinder is gas also and the pressure for both gas inside and outside the cylinder is same at 2180 psi. As time passes, the outside pressure is reduced from 2180 to atmospheric pressure with time e.g. 10 hours. I want to know how the pressure inside the porous cylinder changing? I know porosity, permeability, but do not know how to convert them to what fluent wants? Can you tell me what I should do? I appreciate your replies. You can also email me with rahman.ashena.313@gmail.com. |
Turbulent flow in porous medium | Chander | CFX | 4 | January 17, 2017 09:50 |
Velocity inlet boundary condition for porous medium | Chander | CFX | 3 | March 11, 2012 21:18 |
Lack of local thermal equilibrium in porous medium | Chander | CFX | 4 | March 4, 2012 04:07 |
How to use non-equilibrium thermal model for porous medium in Ansys CFX 13.0? | Chander | CFX | 3 | November 28, 2011 14:26 |
porous medium and reactions | Valeria | FLUENT | 1 | July 10, 2009 03:58 |
