December 30, 2015, 01:54 |
velocity difference ?
cglr
Rep Power: 11 |
I have been dealing with the air flow in a narrow duct comprised of two thin long plates that have a particular temperature. Id like to observe the heat transfer rate between air and plate. I have good mesh at walls ( 0.2<y+<2) and utilized sst model. The thing I could not understand is although I set the inlet velocity 5,4 m/s in the boundary conditions tab, when postprocessing I see a region which has a velocity of 6.08 m/s or velocity bigger than 5,4 (you can see in the attached picture) Id like to see your comments on that. is it possible ? Note: I initialized as all-zones |
In fluent post processing, difference between, x velocity and axial velocity? | padmanathan | FLUENT | 3 | December 20, 2014 15:13 |
Velocity distribution function sampling issue in DSMC | flotus1 | Main CFD Forum | 6 | December 13, 2014 06:18 |
Unexpected difference between velocity / mass-flow inlet | jpo | FLUENT | 8 | December 10, 2010 07:20 |
difference of velocity field processed by CFD-POST and Fluent | Jiuan | CFX | 3 | June 16, 2010 08:23 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
