January 18, 2016, 11:50 |
Thrust of a pipe flow
a m s
Rep Power: 10 |
Hi
I have an unsteady pipe flow (sinusoidal velocity profile) which outputs into a large domain. The geometry is specified as 'axisymmetric'. I want to measure the thrust of the jet a short distance downstream of the pipe exit, how can I do this? I know I can monitor the pressure, velocity and density at a range of monitor points and then put them in a momentum balance equation etc. but the only way I know how to do that is setting up parameter points at each monitor point individually. Say I had 20 monitor points, that would create 60 output files to then process which isn't ideal. I have tried using a 'rake' but am unsure what data that is outputting as it only outputs one value for the whole 'rake'. Would I use integral, mass-averaged, area-averaged?!?! And how would I then calculate the force for fully revolved pipe? I know there must be a quick and easy way to do this and I have tried looking but it either outputs 'zero' or I'm not certain what it's outputting (and hence how to interpret the value!) Any help would be hugely appreciated, thank you. |
January 20, 2016, 02:32 |
Lucky
Rep Power: 66 |
You could create a function, either a custom field function or a UDF for the stream thrust and then you could integrate this stream thrust.
monitor, output, pipe, thrust |
Plotting of Graphs of Reynold Number Versus Length In Counter Flow Double Pipe in CFX | Shomaz ul Haq | CFX | 1 | January 4, 2016 12:16 |
Setting boundary conditions for simple pipe flow with flow direction changing in time | Sipher | FLUENT | 1 | May 4, 2015 20:05 |
[GAMBIT] meshing in GAMBIT, a flow through a pipe having complex inflow geometry | mazhar1613 | ANSYS Meshing & Geometry | 1 | January 11, 2012 23:18 |
[ASK] Flow in Corrugated Pipe with FLUENT | Primadhani | FLUENT | 1 | May 11, 2011 20:41 |
Pipe Flow | Saima | CFX | 1 | January 10, 2011 16:41 |
