January 26, 2016, 15:57 |
aspect ratio
shahin
Rep Power: 10 |
hi
I want to know what is The appropriate amount of aspect ratio? thank you. |
January 27, 2016, 02:45 |
amirhossein
Rep Power: 11 |
January 27, 2016, 03:01 |
shahin
Rep Power: 10 |
January 28, 2016, 04:56 |
Rick
Rep Power: 26 |
In general, aspect ratio should not exceed 20; but if you are speaking about aspect ratio of cells closed to wall surfaces, this can reach up to 200 (to be able to reach the correct y+ value).
You can use higher aspect ratio if fluid streams are aligned with the cell. Daniele
Google is your friend and the same for the search button! |
January 28, 2016, 13:48 |
#5 | |
shahin
Rep Power: 10 |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
[Other] Aspect Ratio CFX Solver | tomson199 | ANSYS Meshing & Geometry | 4 | August 27, 2015 10:12 |
Grid Aspect Ratio | harishameed33 | Main CFD Forum | 1 | August 11, 2012 22:35 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
High Aspect Ratio elements | Flavio | CFX | 2 | November 24, 2006 12:01 |
