Meshing a wind turbine blade
Old   February 2, 2016, 20:32
Default Meshing a wind turbine blade
numan
mrswordf1sh is on a distinguished road
Hi guys,
I am trying to validate my numerical method using NREL Phase VI blade in ANSYS FLUENT, but I am having hard times with meshing. I am using the standart meshing component of ANSYS. I just define face sizing, body sizing and infilation, I barely get 0.9 skewness having 12 M of mesh elements.
I tried different sizing and methods, but still I can't increase the mesh quality. I have attached the picture of the fluid domain and other mesh sizing details. Do you have any advice?
My power output results are arround %20 worse than experimental results.
What should be the range of Y+ for k-w SST model?
One more thing, the rotation direction of the Moving Domain inside is +z, that it true right?
Thank you.
mrswordf1sh is offline   Reply With Quote
Old   February 4, 2016, 21:27
Aja
aja1345 is on a distinguished road
Value of Y+ should be equal to 1.
It seems that rotation direction of the Moving Domain is right.
Did you use structure mesh in computational domain?
aja1345 is offline   Reply With Quote
Old   February 5, 2016, 22:16
numan
Thanks for the response.
Nope I used unstructured mesh. Since the blade has a complex geometry, I guess it is almost impossible to use structured mesh.
Do I need to learn to use ICEM CFD or some other meshing software for meshing? It seems very difficult to get a quality mesh with ansys meshing:/
And btw, the wind turbine blade should be stationary wall and not moving wall right? I just have to rotate the moving frame?
Old   February 6, 2016, 15:21
Aja
Ok,
I use Gambit but I am agree with you about "Since the blade has a complex geometry, I guess it is almost impossible to use structured mesh"
But i had seen a few tutorial about meshing of wind turbine in Gambit. Also Did you study the following links and download them?
https://www.google.com/?gws_rd=ssl#q...2FWind+turbine
Above links are useful. there is a youtube link....
Old   February 9, 2016, 18:55
numan
thx for the responses, it helped me.
Strangely, if I use patch independent method (using tetra mesh), skewness and orthogonal quality values get much better, but mesh looks generally awfull.
So, should I still use it?
Anlysing and Calculating the power output from a wind turbine blade mrswordf1sh FLUENT 1 July 13, 2017 01:42
3D wind turbine blade analysis mrswordf1sh FLUENT 0 April 4, 2015 20:17
[ANSYS Meshing] wind turbine simulation meshing problem maxwell94 ANSYS Meshing & Geometry 0 January 26, 2014 13:06
Can I use Turbogrid to mesh a wind turbine blade? Henry Liu CFX 10 November 10, 2011 05:41
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case LittleBart Main CFD Forum 5 January 10, 2011 15:07
