Incorporation of heat generation into a solid |
February 15, 2016, 00:09 |
Ashish Saxena
Hii,
I am simulating a solid cylinder with a fluid pipe inside (blood vessel inside the arm) and I want to incorporate heat generation in the whole solid part similar to the heat generation in the arm tissues due to metabolic activities using fluent. Any suggestion on the same??? Thanks for your help in advance. Regards |
February 16, 2016, 00:53 |
Lucky
Rep Power: 66 |
You can add a volumetric heat generation (W/m^3).
From the GUI, go to cell zone conditions, edit the zone, check the box to enable the source term. Then go to the source term tab and create an energy source. |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
heat conducting in a solid domain | Rogerio Fernandes Brito | FLUENT | 0 | March 18, 2008 17:25 |
heat conducting in a solid domain | Rogerio Fernandes Brito | Fidelity CFD | 0 | March 18, 2008 17:24 |
heat conducting in a solid domain | Rogerio Fernandes Brito | CFX | 0 | March 18, 2008 17:20 |
Heating of a solid cylinder with internal heat generation | Sriram Popuri | Main CFD Forum | 6 | July 13, 1999 18:09 |
