How to define two seperate boundary conditions? |
February 28, 2016, 03:52 |
Akr
Rep Power: 11 |
Hi all,
I want to know, how can i give two seperate boundary conditions on a part. for eg: suppose i have a long cylindrical tube. i want to give two set of boundary condition on this tube. 1. the upper end (if i cut it along diameter) of the tube has a flux condition which is some value. 2. the lower end of the same tube has a flux condition of some other value. may i know, how to do this? |
February 28, 2016, 20:54 |
Lucky
Rep Power: 65 |
You need to split that boundary into two separate distinct boundaries. Then you can apply your individual boundary conditions to each.
You can try to split it in Fluent (which might not work), or go back to the geometry/mesh and split it there. It's better to split it during the geometry/mesh generation process because you need the cells to be generated properly on those faces. |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
How and what to define on boundary conditions for embedded heating block | HamidN7 | FLUENT | 0 | October 16, 2015 14:00 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
