March 3, 2016, 19:59 |
Simulation of a emptying gas cylinder
Alexander Comsa
Rep Power: 10 |
Hi everybody,
I want to simulate a gas cylinder that that is open and closed periodically but I have problems with defining the Boundary Conditions. I do not know how to define the interior of the cylinder as there is no inlet. How can I specify that the interior is a gas at certain pressure? Also is there any way I could put a periodic opening and closing of the outlet? Many thanks |
March 4, 2016, 00:13 |
Have a nice time!
Rep Power: 11 |
Check the tutorials out....I am sorry I cannot help you with more information.
https://www.google.com.eg/?gfe_rd=cr...cylinder+ansys |
March 4, 2016, 05:34 |
#3 | |
Alexander Comsa
Rep Power: 10 |
March 6, 2016, 00:49 |
Lucky
Rep Power: 65 |
I'm not quite sure what your problem is. Your interior and inlets/outlets should have been done already after you meshed the geometry. Do you even have your geometry defined? How about a mesh?
The interior is independent of any boundaries (inlet and outlets). The fact that there is no inlet has no effect whatsoever on the interior. There's several ways to model a periodically open and closed valve but it depends on what the user is trying to do. If you can define precisely how you want to model the action of the valve opening then maybe someone can then help you with the implementation. Valve opening and close is too vague. Does it close instantaneously? Does it close completely or can it leak? What does the valve actually do? How do you want your valve to behave? Once you have clearly started your problem, it is fairly straightforward. Unfortunately, Fluent is not the place for you to still be brainstorming. |
March 6, 2016, 01:54 |
Alexander Comsa
Rep Power: 10 |
Thank you for your reply,
The problem is that, after importing the mesh in Fluent I do not know how to define the interior of the cylinder as being a gas with a certain pressure. All the simulations I have done so far had inlet and outlet so the boundary conditions were easy to define. In my case I want to see in time how the gas density profile changes inside the cylinder when I open or close suddenly the outlet. I could define the outlet as "pressure outlet" but how can I feed the gas when there is no inlet? The valve can be idealised as a instant open or close. |
March 6, 2016, 10:41 |
Lucky
Rep Power: 65 |
It is a closed cylinder so you do not need any inlets.
What you have is a transient problem. Therefore you need to specify the initial pressure of the contents via the initialization. Use a pressure outlet for when your valve is open. When the valve is closed, change it from a pressure outlet to a wall (no-slip or slip wall). You can do this manually or automate it. |
March 6, 2016, 20:24 |
#7 | |
Alexander Comsa
Rep Power: 10 |
March 6, 2016, 23:30 |
Alexander Comsa
Rep Power: 10 |
I have added two extra zones, as shown in the attached picture. If I do not bother too much could you please tell me how I can specify that the gas flows only from the middle zone? I have no option in the Initialization to choose any of those zones. I have defined the outer shell of the added zones as pressure outlet and the outer shell of the middle zone as wall. The interface between zones is defined as interior.
March 7, 2016, 01:46 |
#9 |
Alexander Comsa
Rep Power: 10 |
Last edited by ticofiz; March 7, 2016 at 02:32. Reason: I put a question without checking properly my simulation. |
March 7, 2016, 07:54 |
#10 |
Lucky
Rep Power: 65 |
You can patch variables in individual zones if that's what you're asking about.
March 7, 2016, 19:00 |
#11 |
Alexander Comsa
Rep Power: 10 |
boundary conditions, fluent |
Simulation of radial gas turbine, Inlet velocity components | dmaz | CFX | 17 | May 19, 2019 09:45 |
gas turbine combustion chamber cold flow simulation | chawane | FLUENT | 1 | January 21, 2016 10:56 |
Ideal gas v.s. Real gas for wing simulation | Anna Tian | Main CFD Forum | 1 | December 16, 2013 11:39 |
modification for rotating cylinder simulation | zonexo | Main CFD Forum | 3 | July 21, 2006 14:24 |
Tracer gas simulation with CFX4.3 | CFX 4.3 users | CFX | 3 | August 15, 2003 05:38 |
