Problem with convergence monitors
Old   March 21, 2016, 08:49
Default Problem with convergence monitors
ryan
Ryan_Yang is on a distinguished road
Hi, everyone,
I am trying to judge the convergence of one simulation with one facet average value on the monitoring surface. I activated the the monitor in the 'convergence manager' and defined the stop criterion as '0.001'. The default residuals monitor were deactivated.
It worked fine when I did the steady case and the calculation stopped exactly when the residual of the monitoring value is lower than 0.001. But when I switched the case into transient, the stop criterion failed to work and the calculation went on working until the max iterations per time step was reached.
Does anyone have same experience and know how to fix the problem in transient calculation?
thanks!
Ryan
Ryan_Yang is offline   Reply With Quote
Old   March 21, 2016, 09:29
Jordi Pina
jpina is on a distinguished road
As far as I know, in a transient simulation, this criteria is used not for finishing the simulation but for stopping the iterations of the calculated time step.
jpina is offline   Reply With Quote
Old   March 21, 2016, 09:36
ryan
Hi, Jpina,
thanks for reply!
To stop the iterations of calculating time step is what I want to do. But the calculation won't stop even if the stop criterion are reached.
Old   March 21, 2016, 09:50
Jordi Pina
Maybe not all the stop criterions are satisfied: Courant number for explicit, truncation errors, other residuals...?
Old   March 21, 2016, 10:05
ryan
Hi, Jordi,
Monitors on the other residuals were turned off. Are Courant number and truncation error checked for convergence in FLUENT?
Old   March 21, 2016, 10:09
Jordi Pina
Only if you use variable time step!
Old   March 21, 2016, 10:17
ryan
The time step is fixed...So I guess the surface-monitored value should be the only criterion that checked for convergence.
Old   March 21, 2016, 10:51
ryan
It seems to me that in transient calculation, FLUENT calculates the residual of user-defined monitoring value at end of each TIME STEP, which based on the value of current iteration and last iteration at pre-time step. Once the criterion is reached, the whole calculation will be stopped.
what is the point of doing so? why not applying the same convergence monitoring method of default criteria (continuity, x,y,z-velocity,.....), which calculates the residual at each iteration and jump to next time step when convergence is reached.
I am now in big confusion .
convergence criteria, transient
Convergence problem in Fluent for quenching process kaeran FLUENT 4 December 1, 2014 02:14
Rotate frame reference convergence problem! wjy-c CFX 2 September 26, 2014 06:03
Centrifugal pump OpenFOAM, convergence problem, ANSA model RDD OpenFOAM Running, Solving & CFD 0 July 5, 2014 09:12
Convergence Problem in Axisymmetric Periodic Flow atheresia FLUENT 3 February 10, 2014 03:00
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
