Tracking mass flow rate with position
Old   March 26, 2016, 17:21
Default Tracking mass flow rate with position
prij is on a distinguished road
If I want to track the mass flow rate along the axis of a converging-diverging nozzle and want to find out the value of mass flow rate at a particular distance from the throat, how do I get it? I know that I can generate a curve for mass flow rate vs distance in the results section. But how do I interpolate at a particular point. I want to determine even the minute changes in the mass flow rate (to the order of 2nd decimal change in distance).
Thanks.
prij is offline   Reply With Quote
Old   March 30, 2016, 17:44
`e`
`e` is on a distinguished road
For determining mass flow rates for each cross-section of your nozzle you could use the local velocity and calculate the cross-sectional area. However, of course the resolution of this approach is limited by your mesh size. For finding interpolated values, have a read of this post and check their UDFs.
`e` is offline   Reply With Quote
Discrete Phase Model, outlet mass flow rate does not fit edu_aero FLUENT 29 February 3, 2020 08:38
Mass flow rate: calculation v/s computation beguxa FLUENT 5 December 2, 2018 21:02
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
Determine mass flow rate along flow path Atit Koonsrisuk CFX 2 October 5, 2003 04:47
