Fluent received fatal signal (ACCESS_VIOLATION)
Old   April 4, 2016, 18:06
Default Fluent received fatal signal (ACCESS_VIOLATION)
Stanley90 is on a distinguished road
Hello
I have problem with Fluent, which ejects me that kind of errors stored in cortex.txt file. Does anyone can help me to find out what this refers to??
Error [cortex] [time 1/27/16 23:44:53]
C:\PROGRA~1\ANSYSI~1\v145\fluent\fluent14.5.0\win6 4\2ddp\fl1450s.exe received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Stanley90 is offline   Reply With Quote
Old   April 4, 2016, 19:47
`e`
`e` is on a distinguished road
Are you using any user-defined functions? If so, what are they and are you using user-defined memory?
`e` is offline   Reply With Quote
Old   April 5, 2016, 01:18
Surya
hariswch2 is on a distinguished road
Originally Posted by Stanley90 View Post
Hello
let me know, when this error came....while running simulation or while open fluent...? most probably this was due to license or Ram problem
hariswch2 is offline   Reply With Quote
Old   April 5, 2016, 01:22
No, this case is calculated without UDF's..
Old   April 5, 2016, 01:32
I think it's rather problem with graphics, because I can launch Fluent and any case without problems but the graphics window display nothing
It looks like on attached image
Old   April 5, 2016, 01:51
Surya
Ya...it is taking the Mesh but it was not showing means make sure do you tick the DISPLAY MESH Option before opening fluent
Old   April 5, 2016, 02:22
No, I think you're wrong, because I also checked Fluent launching with this option..
I'm pretty sure that's graphics problem because I have on my computer integrated graphics card and additional Nvidia's one. So, when I try to launch Fluent with this second, graphics window works normally, but error I indicated is still present.
Old   April 6, 2016, 11:19
Does anyone can help to find a solution?
FLUENT received fatal signal (ACCESS_VIOLATION) CHAKER FLUENT 4 December 11, 2015 03:20
FLUENT received fatal error saikat FLUENT 2 October 5, 2015 17:33
FLUENT received fatal signal (ACCESS_VIOLATION) Mike Wong FLUENT 7 October 17, 2014 13:17
FLUENT received fatal signal (ACCESS_VIOLATION) rubis Fluent UDF and Scheme Programming 6 April 22, 2014 15:42
FLUENT received fatal signal (ACCESS_VIOLATION) samy FLUENT 0 November 10, 2007 13:09
