April 6, 2016, 19:49 |
how to delete the walls in fluent !!
settou belkhir
Rep Power: 10 |
hi all
i am new here & i need some help please !! I am generating mesh for a collector solar with MCP, i have problem of the walls was created automatically by GAMBIT between the solid a fluid & i want to delete them OR deactivated !! thanks |
April 6, 2016, 23:23 |
Pedro Henrique Di Giovanni Santos
Rep Power: 10 |
Wy you do not import Just the fluid body ?
April 7, 2016, 10:32 |
settou belkhir
Rep Power: 10 |
April 7, 2016, 10:48 |
Rep Power: 10 |
So you need to know the temperature between blue and yellow body?
I never worked with FLUENT, but i think the*DesignModeler*is the same. On CFD in this case like that I work with different body, and on solver I will try to use boundary conditions to now the temperature o this interface |
April 7, 2016, 17:00 |
Lucky
Rep Power: 66 |
Just delete the surface from the mesh. If you're using v17 it's in the "setting up domain" ribbon. On older versions it's under "mesh" tab in the file menu.
How to conduction in fluent insulated walls ? | hegelim34 | FLUENT | 6 | November 10, 2014 12:01 |
Unknown walls generated when import .msh file to fluent. | mdw0821 | FLUENT | 4 | October 16, 2012 13:32 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
On Bug of Fluent 12.0 | lzgwhy | FLUENT | 0 | August 26, 2009 06:41 |
Delete cells in fluent | Christian | FLUENT | 1 | December 5, 2003 12:04 |
